JEFF TURNER
New User
Two questions I would like some advise on please?
1) Irecently discovered that my rebuilt TEF20 has the fuel pipe from the main tank directly connected to the the two fuel filters missing out the auxilary tank. Never had any problems and its not to hard to reconnect, so if it aint broke why fix it. Do you think I am OK just to leave as is?
2) Some times when starting the TEF20 the starter moter does not turn not even a faint click. The battery is ok, and I have taken the starter off and checked the bushes, and cleaned all electrical connections. What other problem could result in the starter motor not operating on some occasions? When it does go it seems fine with plenty of power to start the engine. Do you think it may be the mechanical switch operated by the gear lever? Or what else could cause this occasional problem.
