Carb info please
Hi, I have a 51 tea20 with a 24S Carb and I can only find info on 24T carbs. Doe's anyone have a link to adjusting this carb?
Thanks for any help...
Also the motor seems to run a little better with the fuel shut-off above the sediment bowl open about 1/2 a turn? It revs higher at this setting then if I open it any more idle slows down & it seems to run rougher? Why?
More info needed please: I was just looking at my carb to see what I need to do to try & adjust it after getting some info from John (Thank you).While I was checking out the [color=red:793b08ed79]"Idle Speed Screw"[/color:793b08ed79] I see that it screws into a tab on the side of the carb but doe's[i:793b08ed79] not[/i:793b08ed79] push on anything to actually adjust the idle?
Doe's anyone have a picture of how this is supposed to work or of what part I'm missing :?:
Here is a photo of idle screw placement:
Below is a pic of my carb if it helps.
_______________________________________________
