Stephen Ford
New User
I have been reading various opinions between resistor and non resistor spark plugs used on these older tractors and wanted to hear what you all had to say about using resistor plugs on a TO-20?
Let me explain why I am interested in a resistor plug, maybe I have other problems. I have been having charging system issues (tractor is all stock including 6v charging system) so using a multi meter I attempted to check charging system voltage, but as soon as I get anywhere near the battery my meter goes crazy. Removed belt from generator and same problem exist. Replaced spark plug wires with modern wires and still same concern. Inspected spark plugs and realized they are non resistor type. Could this be causing my interference problems or is it possibly a bad capacitor or points concern in the distributor?
As a side note the generator checks out ok so I am assuming the regulator is at fault, but I would love to get a voltage reading with this thing running before I go buying parts that I may otherwise not need. Thanks for any help you may provide.
Steve
Steve
