Here is a useful explanation from
Wikipedia:
Pre-ignition (or preignition) in a spark-ignition engine is a technically different phenomenon from engine knocking, and describes the event wherein the air/fuel mixture in the cylinder ignites before the spark plug fires. Pre-ignition is initiated by an ignition source other than the spark, such as hot spots in the combustion chamber, a spark plug that runs too hot for the application, or carbonaceous deposits in the combustion chamber heated to incandescence by previous engine combustion events.
The phenomenon is also referred to as after-run, or run-on when it causes the engine to carry on running after the ignition is shut off, or sometimes dieseling, in reference to the fact that a heated diesel engine may, by design, run without an external ignition trigger so long as a suitable fuel/air mixture is supplied to the cylinders. This effect is more readily achieved on carbureted gasoline engines, as the fuel supply to the carburetor is typically regulated by a passive mechanical float valve and fuel delivery can feasibly continue until fuel line pressure has been relieved, provided the fuel can be somehow drawn past the throttle plate. The occurrence is rare in modern engines with throttle-body or electronic fuel injection, as the injectors will not be permitted to continue delivering fuel after the engine is shut off, and any occurrence may indicate the presence of a leaking (failed) injector.
Preignition and engine knock both sharply increase combustion chamber temperatures. Consequently, either effect increases the likelihood of the other effect occurring, and both can produce similar effects from the operator's perspective, such as rough engine operation or loss of performance due to operational intervention by a powertrain-management computer. For reasons like these, a person not familiarized with the distinction might describe one by the name of the other. Given proper combustion chamber design, preignition can generally be eliminated by proper spark plug selection, proper fuel/air mixture adjustment, and periodic cleaning of the combustion chambers.
I had a similar problem in my Jaguar but I solved the problem with higher octane fuel.
Check your spark plus heat range, ignition timing and fuel mixture before you think about pulling the head off. On old trick of my youth for de-coking an engine was to dribble upper cylinder lubricant down the carby with the engine running. I guess it works - certainly makes a heap of smoke! :lol:
