[b:1de702c4bc][i:1de702c4bc]semlin;
I'm the goofy FORD guy, that Jerry told ya about!!!! Yes, I work on carb's, specifically, M/S TSX carb's for the Ford guys on the YT 9N,2N,8N forum.
Since you will not come over there, I decided to make a "House call", just for you. :lol:
This first picture,(I talk with them)....shows how the choke plate and the flapper spring is laid into the choke area of an M/S carb. I've seen them laid in....upsidedown, and backwards. You will note that there is a slot in the middle of the choke rod. The choke plate fits snugly into that slot. then the flapper fits over the back of the rod, held in place by the flapper spring. CLEAR as mudd!!!! right?????? These are to be assembled, before incerting the plate into the choke housing slot.
Here's yer pic.:
This next pic., is a cut-away veiw of an M/S TSX carb. This will show ya, all the passages and jets, and places that MUST be clear of ALL debrie, and gunk.:
When I do a complete overhaul of this type of carb. I soak the carb. in a can of carb. cleaner, for at least 2 days, before I attempt to blow out all those little hiddie-holes, with about 80 lbs of air through a rubber tipped air nozzel. DO NOT BLOW AIR into a carb. until it has been fully dismantled!!!!!!!!!!!! :roll: You prob. will be buying a new carb.!!!!!!
Hope this will help ya in some small way.....The house call is over....and I'm going home!!!! :shock: :? :lol:
Gary
YT alias: GB in MT 8) [/i:1de702c4bc][/b:1de702c4bc]
Here's yer pic.:
Gary
