Hi everyone,
I finally got my TEA20 running again today!
Now I have a few questions.
[b:0ea8810031]1 - S[/b:0ea8810031]ince replacing the part of the throttle linkage shown in the first picture below, the tractor idles at much higher revs. This was much more noticeable when the engine was warm. I assume the throttle is not closing all the way. When I fitted this part, I thought I had fitted it in such a way that the throttle was fully closed with the lever fully upwards. Is there a special technique to doing this? Is it possible the clamp has slipped on the rod? Any tips would be appreciated.
[b:0ea8810031]2 - T[/b:0ea8810031]he fan belt is slipping. I bought a fan belt on ebay for a TEA20, and found it to be at least 2" too long. I was told that this was because I have converted to an alternator. I fitted a fan belt from a Volvo 240 just to get it going, but as I suspected, it is slipping. Where can I buy a suitable fan belt?
[b:0ea8810031]3 - T[/b:0ea8810031]he starter motor is completely dead now... at least I think it's the motor that is the problem. For a while now, it would crank, then the starter would cut out, then cut back in, etc. A few times today it did that, then stopped working completely. A while back I also saw smoke coming off the starter while cranking for less than 5 seconds. How difficult would it be to wire up an alternative circuit to test if it's the starter or the switch that is causing the problem?
