"Is it possible to put the flywheel on wrong so that the timing mark is 180 deg out?"
"I have no timing marks at all. Nothing."
[b:6f321ab822]Doc[/b:6f321ab822] ...... C'mon now - how do you time the 80 mm engine if there are no timing marks??? :shock:
[b:6f321ab822]Bendee[/b:6f321ab822] is correct - Manual page G.17 para 2 (c) states:
[i:6f321ab822]"tractors of early manufacture have a vee mark on the inner rim of the fan belt drive pulley and a corresponding cast mark on the timing cover"
[/i:6f321ab822]
Manual page C.33 para 12 states:
[i:6f321ab822]"Replace flywheel. Dowel holes in flywheel are 90° apart while those in flange are 180° apart. Thus relocation of dowel provides four alternate positions for flywheel."[/i:6f321ab822]
I can't find any manual references to a "correct" position for the flywheel.
I've never seen the timing marks on an 80 mm engine but the following appears logical:
1. The position of the flywheel on the crank shaft flange can not affect valve or ignition timing as the timing marks are on the [u:6f321ab822]front[/u:6f321ab822] crankshaft pulley and timing case, [u:6f321ab822]not[/u:6f321ab822] on the flywheel.
2. I'm guessing you have the option to mount the flywheel in any of four positions due to either: crankshaft/flywheel balance; or to change the position the starter motor engages the ring gear?
I doubt it is balance as that would imply the crank shaft and flywheel were dynamically balanced as one unit at manufacture - I've only ever seen that on performance engines and there would probably be matching marks.
The starter motor pinion generally only engages the flywheel ring gear in two (?) positions, which should be apparent from ring gear wear. I'm guessing, but you can probably rotate and relocate the flywheel 90° out from it's previous position, to present an unworn section of ring gear to the starter pinion???
In answer to your original question: I can't see how flywheel position can have any affect on valve or ignition timing.
[i:6f321ab822]Caveat Emptor![/i:6f321ab822]
Posted at 04.59 am - back to my early morning coffee!! :lol:
Bob in Oz
'53 TEA20
