I need knew rear seals and axle bearings.
It's easy enough to remove the axle shafts but has anyone DIY'd the shrunk on collar that holds the bearing and one of the seals in place?
Any tricks, hints?
Will an oxy torch heat it enough to remove it?
Does it need to be drilled and spit with a cold chisel?
Are the collars easy to find?
I hate out sourcing stuff. But I will if I have to. :roll:
[/b]
Any tricks, hints?
[/b]
