Massey 65 won't start
Fergy63
11-15-2023 12:30:12
Hello.
I have a 1960 Massy 65 diesel that won't Start. I undid the fuel line at the injectors pump and I checked the fuel and it reaches the injectors pump.
The tractor was fine a couple of months ago but sat in the barn since and now with the cooler weather it won't start.
Should I undo an injector and see if the fuel reaches?
I am new to this.
Any leads would be greatly appreciated.
Thanks.
Tom H.
11-15-2023 16:44:34
 Re: Massey 65 won't start in reply to Fergy63, 11-15-2023 12:30:12
Im going to say yes. I have a case 680 backhoe that would needed the lines bled when I got it. You may be able to loosen the fitting to the injector and crank till fuel comes out. Bleed all of them and then go for a start.
Tom
Tom H.
11-16-2023 16:00:43
 Re: Massey 65 won't start in reply to Tom H., 11-15-2023 16:44:34
You can also try some starting fluid spray going into the air intake.
Bruce(OR)
11-17-2023 22:04:33
 Re: Massey 65 won't start in reply to Tom H., 11-16-2023 16:00:43
You just might not desire to operate the glow plugs within 15 minutes of starting fluid. Unless you might not mind an extra hole in the intake manifold.
