Rear engine seal
hajo158
New User
I recently bought a TE20 Ferguson tractor, it's got the Z120 engine. No way to get the engine serial number, as everything is painted over and not legible. Tractor serial number is 27945. I need to split the tractor, as it looks like the rear engine seal needs replaced. Can anyone tell me the part number for the correct seal? Hope it's not the 2 piece rope seal, because I haven't found any video on how to replace that one. Thanks.
Continental Z120 rear oil seal, I think this is what you are looking for.
https://www.yesterdaystractors.com/Ferguson-TO20_Crank-Seal-Rear_1750216M92.html
How is the warm idle oil pressure? They don't run much, so anything off the peg is good.
But if it's low, or bottom end rattling, it may need more than just a seal. An engine with loose mains and
blow-by, the seal may only be a symptom of deeper problems.
There is also a seal on the transmission input shaft. Be a good time to replace it, easy job.
