Mad Farmer
- Location
- Northeast
Hi folks, first post here, I'm usually next door on the N Ford forum.
What brings me here is I've gotten a good deal (I think) from a friend on what seemed to be a TO20.
Turns out to be a Franken-Fergie. I started working on it today and has ser# for 51 TO20 on dash, but a 52 Z129 TO30 engine. I knew in advance two tractors had been used to make this one.
Has been sitting two years inside and it just got evicted from the barn. I'm trying to get it running before I move it. Looks to be original except engine, and 3-wire Delco alternator 12V conversion w/an amp meter (seems correct wiring). Older paint job, sheet metal fine except a few rust holes below radiator
Checked distributor, some mud duabbers moved into the cap. Cleaned that up and the contacts on cap and rotor. Blues Streak points were usable, close to correct gap, cleaned them up and set static timing.
No gas in tank or carb. Added a gallon and no fuel out of carb drain, or fuel line to carb. Took off sediment bowl and just got a slow drip. Inside of tank looks clean so something has junked up sediment bowl/fuel petcock assy. Does not look to be an original, sort of like a Tisco? Were the originals like the ones on the N Fords with on 2 turns, and the reserve setting full out?
I need to drain the tank and take off the sediment bowl. I've heard it's hard to find a good replacement that is not a new POS.
Anyway that is were it sits now, until I get fuel flow. Plugs need a cleaning and will check compression when I have those out.
How did I do for $500? Rear rubber is almost new/no wear but is older and has a few cracks.
I'll have questions when I get into it deeper.
