I recently replaced the starter linkage on my TO20 which was unhooked since when I purchased the tractor. Now it seems like when I shift into reverse it acts like it is moving the reverse gear too far and will
grind if I pull the gear shift lever back too far. The detent is working in neutral correctly. Is there an adjustment that can be made to correct it. As long as I am careful about not pulling it too far it
acts fine. When the tractor is not running it seems like it goes into gear more solidly. Thanks for any help.
