TO-30 drawbar kit
S1att3r
New User
I have a 1952 TO-30 that I would like to add the swinging dreawbar kit to. The primary use would be to pull a hay dolly. The problem is my tractor only has two drilled and tapped holes underneath instead of four. Would the kit still work for my case? I am unable to use a 3 point hitch since once you put a bale on the dolly it has upward tongue pressure and lifts the 3 point to max height.
You should be able to drill and tap for the other two holes. Are you sure that they are not blocked with crud? I would want all four bolts in
place fit the swinging draw bar kit.
Look at the stay bars on the grey Ford.
https://forums.yesterdaystractors.com/viewtopic.php?t=1375900
There is an OEM FERGUSON HORSESHOE DRAWBAR on fleabay right now for $600!!! It doesn't have the required Clevis Bracket or Pin so is useless, and for that kind of
money, you can buy several of the aftermarket kits sold today.
OEM FERGUSON HORSESHOE DRAWBAR - SHOWN w/ THE FORD 8N-802 CLEVIS*-
*The FORD 8N-802 Clevis will not work with the Horseshoe Drawbar on a FORD 8N and after; you need the Ferguson Clevis.
AFTERMARKET SWINGING DRAWBAR sold today:
<img src=https://i.imgur.com/D1EugNch.jpg>​
Tim Daley(MI)
After scratching on the underside of the tractor for a third time I finally found the second set of holes. They were spaced farther apart than I had anticipated.
