Hi!
I'm trying to help a friend fixing his te-20. Sadly, when fixing the hydraulic pump, the fork retracting spring on a lift cover snapped.
Replacement spring was installed, but it is a little bit looser. I think this cause the fork not to move the control valve on a hydraulic pump correctly.
Just slightly bumping the fork with finger via the inspection cover causes the lift to work and the control valve to move just a bit more.
So, if anyone has the fork retracting spring for sale, I would be most interested, or tips adjusting the fork movement.
