retrofit hydraulic filter FE35
mf35a
There was a hydraulic filter kit for retrofitting filter on MF35/MF65 partnr 189505M91 apparently back in the days. Anyone retrofitted filter on FE35/MF35? There is parts that you can buy today but not mounting parts
[/img:24652174e2]
Two different pumps were fitted one with and one without . I really can't see how you could fit a filter to the older FE35 pump but then I've never tried .
(quoted from post at 23:49:51 08/19/22) Two different pumps were fitted one with and one without . I really can't see how you could fit a filter to the older FE35 pump but then I've never tried .
Will fit?
Don't you think these parts will fit?
I haven't tried myself , if the kit is made as a retro fit then perhaps it will . It is tight in there with little space so it would need to be a precise fit .
I have an early FE35 , it is 65 years old and has run without a filter in its original pump for its entire working life . The hydraulic oil stays clean for years , I've never had trouble with impurities in the pump . Is one really necessary for your work ?
(quoted from post at 21:57:06 08/20/22)
Can imagine tight fit but I think there is a reason why it came a kit to upgrade pumps and why they are fitted nowadays. I prefer filtered oil before non filtered no hydraulic pumps comes unfiltered today
