thelonepatriot
New User
I was mowing hay about a week ago with my TO-20. The temperature was in the mid to high 90's. I was using my old dyna-balance mower and running at full throttle in 1st gear. As the day got hotter the tractor would start to act like it was running out of gas. The tank was about 1/3 full. I had plenty of fuel flow at the carburetor and the elbow screen was clean. I added some more gas to the tank and the problem went away for a while. I think the gas was boiling as after a while it started to act up again. After adding more gas it ran fine until the new gas warmed up. The temperature guage was normal and the tractor didn't seem hot. I only use non-ethanol gas in all of my gas powered equipment. I'm sure the fuel is boiling, or close to it. Is there some sort of additive I could add to it to make the gas more stable or is there something else wrong?
