brumbl
I have a TO-35 with a Z134 Contenintal gas engine. I have to swap crankcase pulleys so I can mount a hydraulic loader pump. Is the crank bolt right or left hand thread?
Thanks
It's right thread.
The original bolt is a holdover from the hand crank days, and is a very low grade, maybe cast.
When you go back with the new drive, you may want to find a better quality bolt, like a grade 5 or 8.
brumbl, where did you find the pulley you want to put on? I have a TO-20 with a F.E.L. and a pump driven off of a two groove pulley and was told that they can fail and are hard to find.
