Company Logo (800) 853-2651 Shop Now
New tractor new problem.. yet another update..
K.Campbell
08-04-2022 17:42:35
So i had dad and brother working for me this afternoon, since o can t do much after shoulder surgery. Pulled gas tank and valve cover to find a broken valve spring on number one cylinder. We went ahead and pulled head. Then went ahead and tore down the face of the engine to get to the governor as it has never worked. The governor was all intact, however I noticed the saucer was pushed out. I took it apart and three or four balled fell out. The balls fall out after they ve been replaced so we are replacing governor as well. The valve cover has some rust inside it from condensation so we are replacing that as well, crankshaft pulley is getting replaced due to someone before us removing it as cracking it. So there we are cleaning up block and ordering valve springs, crankshaft pulley as well as governor tomorrow. Does anyone know if a rocker arm assembly off of a to20 is the same as a to30? They look the same but I want to cross reference part numbers.
K.Campbell
08-08-2022 07:50:59
 Re: New tractor new problem.. yet another update.. in reply to K.Campbell, 08-04-2022 17:42:35
I m not really sure either, When I replace head I ll do another compression test and report back.
Charles in Aus.
08-08-2022 02:58:39
So it was a broken valve spring as I suggested , but i still can't understand how the compression could have increased after adding oil to the affected cylinder .
A few psi perhaps but i wouldnt have expected anything significant .
Duner Wi
08-05-2022 05:08:22
Part numbers are the same for TO20 and 30 . Early TE had a different pipe plug at end of rocker shaft but same part$# as later TO20 and 30 for rocker shaft.
Today's Featured Article - Tractor Profile: Ferguson TO-20 - by Staff. When the infamous "Handshake Agreement" between Henry Ford and Harry Ferguson fell by the wayside (that's a story in itself), Harry Ferguson quickly set up manufacturing plants for a United States version of his English TE-20. The TO-20 was relatively the same as the TE-20 except utilized some different casting materials and had a US-style electrical system. The TO-20 was a dead ringer for the Ford 9N and 2N models and they say that Ferguson did this on purpose when the Handshake Agreement wen ... [Read Article]
Latest Ad: Allis Chalmers B runs really well and starts ease tin in good condition [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
