New tractor new issue UPDATE
I just had shoulder surgery Friday and am out of action for a week or two however, I loaned my tractor to my dad while his is in my shop. The plan is/ was to have my dad and brother come over and do the physical work while I tell them what to do. Anyhow, after loaning dad my tractor, he filled it up with his gas from his 40 gallon steel tank. It immediately started missing adn sputtering just like his did king story short and a container of HEET, I think I found the issue of his tractor. I beleive he ad some moisture built up in his tank, it was almost empty when he filled my tractor up. Added the HEET and it runs fine. Now to add it to his tank and see if it clears up as well.
If the tractor has been sitting still for some time the gas/water/alcohol should be in the bottom of the tank,I
would drain it out and your problem might go away.
(quoted from post at 18:25:47 08/03/22) If the tractor has been sitting still for some time the gas/water/alcohol should be in the bottom of the tank,I
It doesn t sit still too awful long
