TE20 Brakes
SteveXW
New User
I am trying to find brakes for 1947 TE20 the brake shoe assembly number is 1810349M1. they are 2 inches by 14 inch liners.
Is there a part number cross reference of the part numbers?
(quoted from post at 14:53:08 07/20/22) I am trying to find brakes for 1947 TE20 the brake shoe assembly number is 1810349M1. they are 2 inches by 14 inch liners.
Check under "tractor parts" here on the forum.. they have two different options for a TE20.
Here are a couple more numbers
1810348M91,sub to/from 1810517M1, 1810517M92, 3620602M91.
You could try 179590
Thanks and I am trying cross reference to the part number I have. I previously bought shoes listed for a TE20 and they were 10 and 3/4 inch and mine are 13 inch.
Thanks, is there a list of cross references somewhere?
answer, Not that I have found for tractors.
I believe I remember TE20 tractors had Girling brakes and TO20 tractors had Bendix.
Here are a couple of #s for linings only 2097011 and 2097011A.Don't know which fits yours. For shoes is says 1270006 for 200,001 and above.
Here is another shoe # for TE20, TE2021.
B1849 lining set should replace these #1851062M91
202631.
(quoted from post at 05:55:38 07/21/22) Thanks, is there a list of cross references somewhere?
202631.
Thanks for the info and the part numbers
About 25 years ago I had a heavy duty truck shop that could re-line brakes and clutches put linings on my shoes. They easily found a set of shoes that fit and glued them
on for me. I just checked with them on a whim but they said it was an easy repair job and they had re-lined tractor shoes before.
