Northvale PA
I went on line to Agco parts. The oil pump cover lists as an available part, but is on back order. And they
could not tell me how long. So, I ordered a reconditioned pump from Wengers. Yes, cost more, but I am
thinking the aggravation of drilling the set screw hole, reaming the bushings and trying to find a new
cover is about even. I am hoping the grinding noise I heard was the set screw churning against the
pump cover. And I am hoping the drag kept the pump working until just before I realized the oil pressure
was near zero. So, hopefully no engine damage. I think the metal grindings I found were the set screw.
While I have everything apart, I need to replace the head gasket and fix the governor. I use this tractor
for a lot of small jobs so hurts to be out of action.
