TO35 Rear Wheel Lug Bolt
phil(va)
I'm in need of four rear wheel lug bolts (studs) for a TO-35. Can't seem to find them. Looked on this site and Steiner, etc. They only carry front wheel lug bolts. These are the studs that go through the brake drum and hold the wheel. I can't imagine why it is hard to find a listing for this part. Any ideas? Thanks.
Thanks everyone. I found the lug bolts (studs). Rest of story: then when I looked closely at the drum I found that someone had broken off the two screws and had welded the drum to the axle. There is a very strong fine bead around half the mated surface. The tractor was in a remote location, so I put the new wheel on with only four lugs in order to move it later to my shop. What a bummer. I'm guessing that after I somehow get the drum off the axle I will need a new drum. Plus, I'm not sure the axle will take new screws.
The screws are only there to stop the drum falling off when the wheel is removed . This won't happen if the brakes are engaged or even adjusted properly . Unless it's for authenticity there's no real need to replace them .
