What are the symptoms of one of these breaking or losing it's spring?
Reason I ask is my '48 has always run really nicely with no surging. Couple of weeks ago it started stumbling and spluttering whilst using a topper. Lots of surging and eventual stalling.
It would barely run above idle. Turned out there was a grass seed stuck on the needle valve which was blocking the fuel flow almost completely so you had to let it idle and fill the bowl before it would run faster for a few seconds.
Once I fixed that and went through everything else it ran fine up to about a 1000rpm but then went into a mad surge cycle.
I've never messed with the governor as it never needed it but despite checking and rechecking the adjustment it still surged if the adjuster was set to just touch or to the 1-2 turns after touch I've read about.
The only way to stop the surging at higher revs or under load is to screw in the adjuster probably 5 turns.
That seems to cure the problem. (I presume this effects it's operation at lower revs)
Back it off and it will start surging again whether under load or not.
I'm wondering if the earlier surging and governor pulsing has put too much strain on an old spring and either flattened it or broken it partially?
Is there a way of telling without stripping the front of the engine?
With governor to carb rod disconnected it runs perfectly at all revs.
