LarryMaine
Well, have gone thru all the YT archives, internets searches, FergusonTractors . org, etc. etc. Lots of paint codes for other paint manufacturers. I want to remain with the NAPA provided Omni Acrylic Enamel paint. I use the etch primer with cat, sealer with cat, and acrylic enamel with cat & gloss enhancer on my Fords. I find this paint is not cheap, but it is very forgiving for amateurs like me, and it holds up well with no fading. The TO30 is not the same gray as the Ford 9Ns or 2Ns. I can't find any original paint on my Fergie, have looked in the usual spots, i.e. inside air filter, under seat spring, etc. I have a list of what gets painted which color, and the MF Ferguson Gray code of M-1001 for 1946 to 1954. There is a code for PPG paint, but this is not for the Omni. So real quick, does anyone else use the Omni paint and if so, can you offer up the correct code or mix figures? Thanks again to all, Larry.
