Harry Ferguson TO20 huydraulics
The TO20 must have the PTO on when raising the blade or implement. When you shut the engine off and the blade is in the raised position will it or should it bleed off and lower the blade
In a perfect world where all hydraulics are new and have perfect seals the implement would stay raised forever. However, a TO20 cannot be new anymore and seals do leak a little in operation so you can expect the implement to settle. Safest option is to always lower the implement when the tractor is turned off. It keeps kids from accidentally dropping the implement on another kid too.
Those came with iron rings in the lift cylinder, so they will creep down.
Should not fall but creeping down is normal.
