warbaby
I THINK they are 300lbs for a complete wheel weight. I have a 2N here for brake work (as in new shoes and sure-seals) that I keep putting off because it has two
sets of these stacked behind each rear wheel (1200 LBS?!).
Lets not talk about rear axle sure seals. Removed my 9N resto project rear axles for inspection and paint, replaced all brake components this week, was planning on just using sure seals, but one entire bearing cone, cup, and outer seal was all busted up. Got the retaining collar off yesterday, and now have to save up to buy a shop press to remove the bearing retainer hub because no bearing puller is long enough. Just spent $26.50 at Lowes buying just a 5 foot length of 3"pvc pipe to install the sure seals after all the other "what a pain" work is done. Shop press at Harbor Freight will run me $200.00, plus another $125 just for the bearing components. Ugh, it just never ends! Larry.
