I just got my first To 20 and have some questions about
WilliamTo20
New User
My to20 has valve on right side I took pictures of it. I just don't know what it for. I also want to know is ok for my tractor to put a front end loader on it. I would like any help that can be given.i do have pictures I can email if it helps. Thank
(quoted from post at 17:42:42 04/22/22) My to20 has valve on right side I took pictures of it. I just don't know what it for. I also want to know is ok for my tractor to put a front end loader on it. I would like any help that can be given.i do have pictures I can email if it helps. Thank
Id have to see a picture, but if the valve is under your right or left upper leg area than its for a hydrolic line out for an implement. I would not put a front end loader on a to20 or 30. Its hard on the front end, clutch and steering gears
Welcome William!
I can't place a valve on the right side unless it's been added. Maybe an
auxiliary port.
As far as a loader, a TO20 is a really light tractor for a loader. No power
steering is a real pain in the arms! Plus, the front suspension is not intended
for the extra weight. It can be run off the belly pump but will be very slow.
Hi William, welcome to the forum. You won't be able to post pictures on here until you've posted several times. But to answer your question, I have a loader on my TO-20. It is a bit slow, but so am I :). It isn't that hard to steer as long as you get it rolling first. I'm told that my loader is a Scharwtz.
well thank you I just want keep mine running didn't know enough just want use for long time I love the picture I found one rated for to20 not sure year it was made I believe the valve has to be a hydraulic valve it got roundknob on it and still thread still pipe
loader on a to-20 not a good idea hyd. are slow will steer hard and it will not lift much and front end is not real strong in the pivot pin area . it can be done but just not much of a loader tractor
Switch front tires to R225/85/16 for easier turning.
Add a 2 piece to the steering arm on top of spindles.
This will reduce the effort to turn when loaded but increases the turning radius.
That can be overcome by the usage of the wheel brakes when turning.
Addition of a Jackson Power steering unit is another option.
The Old Hokie makes a front pump mount you can fab onto the Fergy to get the hyd to operate faster.
That front axle was NOT designed for an FEL. You might also consider welding in a section of steel plate laid into the rear of the center
axle section. After that the next weakness is the spindles breaking off the axle knees.
Good luck with that one.
I cheated and got a new orange interloper, complete with FEL and a few other toys.
. Thank you so much I like this form stuff I learned a lot just few questions I asked is worth putting tacometor sorry for spelling I had 9 n they alittle different I really like the to20 thanks again
