Te20 Fergusonto20
I had a TEA 20 with a Continental bolted in. It had the original flywheel re-drilled to fit.
Also used the original starter. So, I would guess that the reverse would work, too. But the
problem is that the Standard Engine is a bit longer, so the front axle mount also needs some
modification.
