Company Logo (800) 853-2651 Shop Now
A/C Delco Starter Distributor Condensor issues
BlakeABP
11-30-2021 19:27:45
Hey fellas, I got a wierd one for you. Just recently got my engine back from the engine shop. A full rebuild on an old Continental Z129 on a TO30. Spent way more on the rebuild than the darn thing was worth! Oh well, its done now.
Anyways, i just put the whole tractor back together. It was split to pull the motor. Shortly after inital break in, right after i wired back up the alternator she started to sputter. It turned to be a bad condensor on the distributor. However, as soon as I wire my distributor back up it starts having the same issues! I unwire the alternator and she is smooth as butter again. I dont understand how this same alternator wired the same way worked perfectly well before hand and now its doing this. I do have it wired a little weird, but it worked previously. Maybe one of you guys can set me straight and call me an idiot. Thats okay.. i know what I am!
Its a standard AC delco alternatir with the main power lug which goes to my ammeter then to poistive side of the battery. The ground lug I have striaght to the body.. then i have the two smaller terminals labeled 1 and 2. I take positive striaght from the positive lug on the alternator to #1 and then #2 goes to a switch on my console. I flip the switch to pit power on #2 to engage the alternator, and it does engage. I can stick a wrench to the back of the alternator when the switch is made and power shows to be added on the ammeter. As soon as I do this though, ot starts to sputter. Its interfering some how with the condensor.
I would wire the alternator a different way but i dont know of another way that works honestly.. Any ideas guys?
Thanks for your time!
Jim L WA
12-01-2021 10:37:09
 Re: A/C Delco Starter Distributor Condensor issues in reply to BlakeABP, 11-30-2021 19:27:45
How do you have the battery wired, polarity wise?
wore out
12-01-2021 08:03:35
Yes, #2 can have constant power, the power to #1 needs to go off with the ignition switch, or an oil pressure switch can be used to supply power to the #1 terminal only when the engine is running/has oil pressure, Massey actually used an oil pressure switch to power the gauges and excite the alternator on some tractors when built.
It is a good idea to have an indicator lamp, a resistor, or a diode in the #1 "excite" lead.
J.Wondergem
12-01-2021 06:36:05
wore out
11-30-2021 20:41:49
" I take positive striaght from the positive lug on the alternator to #1 and then #2 goes to a switch on my console"
That's EXACTLY backwards, but still doesn't explain the rough running issue you are dealing with.
BlakeABP
12-01-2021 05:24:26
 Re: A/C Delco Starter Distributor Condensor issues in reply to wore out, 11-30-2021 20:41:49
So i should put power to the number two terminal all the time and the on the number one terminal should i run another circuit from positive with a light in series to excite the alternator? Is that how it would typically be done instead of using a switch?
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
Latest Ad: For sale 1961 ford delta with good fluid filled tires on rear starts good in warm weather. Needs a little TLC price 1200.oo. Calls only . [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
