Company Logo (800) 853-2651 Shop Now
TO 20 Timing?
ajhbike
11-28-2021 16:29:26
I had to change the starter spring on a friends 20... Broken spring... And was told i had to pull the distributer to pull the starter (found out i didn't need to after of course). I was careful to take it out and put it back without advancing the gears...BUT it was doing some popping and burping when we finally started it up. I loosened the distributer and twisted it 1/4"and it got much better. Went a little further and it got a little worse so i put it where it sounded better. Only pops once when we give it the gas.
Is that a way to adjust it?
Is a pop and a little falter when revving maybe a carburetor issue?
ajhbike
11-30-2021 10:51:22
 Re: TO 20 Timing? in reply to ajhbike, 11-28-2021 16:29:26
thanks to all...I will give it a whirl and report back
Jim L WA
11-30-2021 10:35:15
The distributor shaft rotates C.C.W. So, to advance the spark, you would move the distributor body C.W. and of course to retard the spark you would move it C.C.W.
Make sure the plug wires are seated onto the cap towers. One or more may have come loose while you were working with it.
ajhbike
11-30-2021 05:35:45
Thanks.
How would one advance and retard? By slight twists of the distributor assembly like I did before?
Steve@Advance
11-29-2021 20:01:00
Setting the timing by ear is the most common method. The old low compression engines are forgiving.
As long as it's not kicking back against the starter, or clattering under load, it's pretty close. I usually advance it to the best, fastest idle, then back it off just a little.
As for the occasional stumble, try backing the main jet adjustment (the large knob) out 1/4 turn at a time. It should take sudden throttle without hesitation. Keep up with the changes and you can always put it back if you don't like the results.
ajhbike
11-29-2021 14:54:18
Phooey, I don't know how to do that so I will have to research it...plus I don't have the shop manual so I will have to figure that out too. Bummer
Dan S (NY)
11-29-2021 08:21:13
You are probably just not timed correctly. To pull a distributor and put it back in the same place, you would have to mark the relationship between the distributor body and block, and take the cap off and mark the position of the rotor before you pull it out. This will let you know how to line everything up correctly when reinstalled (as long as the engine isn't moved while it's out). At this point you have it running so you probably aren't that far off. I would now adjust it using a timing light to get the timing correct using the service manual. If it's to retarded it can run hot, and if it's to advanced you can get pinging that can be destructive.
ajhbike
11-29-2021 05:49:49
It ran great and consistent before, so i assume the points are good since we didn't touch them. I had removed the whole distributer and never opened the cap
I didn't say bigger carb. I asked whether that could be a contributor
Bruce(OR)
11-29-2021 05:36:44
Was it popping and farting before? Was it even running? Points are gapped at what? Before you play with the defenseless carburetor, get the electrical straight first. No, a bigger carburetor will not make it go fasss-ter or magically fix your electrical problems.
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
Latest Ad: For sale 1961 ford delta with good fluid filled tires on rear starts good in warm weather. Needs a little TLC price 1200.oo. Calls only . [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
