T020-PTO Fluid
CKain(MI)
I do not get any oil on the dipstick thats below and behind the pto lever.
Do I add oil in the hole next to the gear shift lever, on the trans cover ??
Thanks
Yep, that's the fill hole. Some folks remove the lowest bolt on the dipstick cover and fill until oil comes out of the hole instead of trusting the dipstick. It takes a while for the oil to flow from the fill point to the rear section of the tractor, so be patient. Add a quart and wait for 4~5 minutes, then add another if necessary.
BillL
Has the oil been changed in a while? Those are known for collecting water, especially if it's been outside.
Might crack one of the drain plugs and see if you get water. Be a good time to change it if wet or dirty.
90w mineral oil or 15w-40 diesel oil.
