FERGUSON TRACTOR
billkyte
New User
I HAVE INHERITED AN OLD FERGUSON TRACTOR. THERE IS NO MODEL NUMBER OR SERIAL NUMBER
I NEED THE MODEL NUMBER TO GET PARTS[/img]
I HAVE PICTURES BUT DON'T HOW TO POST THEM
This post was edited by billkyte on 09/17/2021 at 04:36 am.
If you have the pictures saved on a drive on your computer, when you post, scroll down until you see the upload photos/videos option. Click on "choose Files" and then navigate to the picture that you want. It'll help to post them.
If you need help to get the pictures to your computer, that's a different discussion depending variables.
Welcome to the forum. Not always, but in many cases new users have to have 5 or more posts on record before the site lets them post pictures (or links), due to site spam filters. Another option is to go down to the Site Comments Forum and ask YT Support for permission to post prior to that. You can try going down to the Test Forum and making several posts there to get your post count up, trying to attach your pictures to each post. That may work after you make several posts. Then make your post here again. It may not work immediately after you get past the 5 posts, if not, you might try logging out and back in at that point. There is a size limit as well, I think it is a total of 7mb per post (be it one picture or the total of several). Some pictures (often taken with phones), are too large and have to be reduced before they will post.
Where is the Engine OIL FILTER located?
Either of these picture correct....AS in OIL FILTER location..?
Either of these pictures correct.....TOP OF TRANSMMISSION cover.....??
Bob...
Just looking at the dash and the front grill it may be a TO20. Oil filter is in the oil pan and you will see a round cover that gets removed when you
change the filter.
The serial number plate was originally on that flat plate above the steering column. I can't see for sure from your photo, but you might try using some brake clean, carb. cleaner or paint remover and see if it's still there. That's what I had to do with mine.
