Howdy Folks,,,, I am feeling like I may have finally got to where I been wanting to be for a long time with My Ferguson TO20. The tractor I picked up over the past weekend has an engine that is sure looking like a keeper!! The PO assured me the engine was in great running condition except for the bad oil leak out the rear main.
I finally got to where I could get a good close look up into the bottom of the sleeve web area and I am overjoyed as there is NOT any evidence of a crack in any of the webs between the cylinders,,,!!!! YEA, Yea, Yea,,,!!! In fact, the cooling system of engine was full of antifreeze when I removed the radiator and is very clean inside, more Yeas,,!!
As I reported earlier, I thought the rear main had shifted and there was an obvious misalignment of it to the block,,? The PO had removed the two rear main bolts (??) and the rear main itself had shifted inwards. I went ahead and removed the rear main so I can repack the two sides of the rear main to the block and I'll be ready to install the oil filter and close up the oil pan, hot wire the coil and put a spark in it to hear it run, before I bolt the two halves together,,,,,wish me luck, fellows,,,!!!!
