Matching Agriline TE20 Grey
NKirov
I've just bought some Agriline TE20 grey paint, assumed it would be a solvent single pack but turns out it's enamel, I gave it a go as I needed to get some bits reassembled at the weekend and it's fine for brushing and on
castings but it's soft and takes forever to dry and I'd rather use two pack especially on the tins. It looks pretty accurate in terms of colour but has anybody ever matched to this colour using the info here?
http://fergusontractors.org/nfs/wp-content/uploads/paint/Paint-Color-Numbers.pdf
Which BASF is closer 01520 or 76806? or Dupont 652?
I don't have a paint factor local to me so would order it online, probably using BASF or DUPONT codes but would obviously like it to be as close a match as possible. I've only sprayed a few bits so far but still would rather not
have to redo them.
Thank you!
Save the paint you have for implements but add a hardener to it , this creates a really durable finish . Wear a respirator though , it's nasty stuff .
I painted my TO20 with DuPont 652 and have been happy with the color. From memory when tractors were new 652 seems correct.
This may be of interest.
https://forums.yesterdaystractors.com/viewtopic.php?t=671359&view=next
Never thought of adding a hardener to enamel, didn't realise it could be done. Now a quick Google shows it to be a common thing especially with tractor enamel. You learn something new every day!
Seems like nobody recognises the Dupont code in the UK or any of the other systems on that list, phoned Vapormatic and they said it's specially mixed so no paint code for it.
I have RAL and BS colour charts but none of those seem quite right either.
Have contacted the owners club here in the UK to see if they can shed any light on the correct code.
