TO20 to TE20
stableboy
New User
Working on a TE20 and need to replace rear end housing because of damage that is irreparable. Will a TO 20 rear end housing fit and work on a TE20. Seems to be all that is around is TO housings and rear-end assm's. Will a T0 20 transmission bolt up to a TE 20 engine.
This message is a reply to an archived post by stableboy on April 10, 2021 at 18:21:25.
The original subject was Fergie Newbie.
What was the final outcome of this Tractor.?
Bob..
Information as per FERGUSON PARTS BOOK.....
Bob...Owner Ferguson TEA-20
Bob..[/quote]
Bob thank you for your interest in the outcome of my springtime project. I was able to fix my rotating valve washer and it works great. Spent many hours and $ on it. I am proud to say it's alive and kicken. Have used it for 20 30 hours and have had no problems No oil in rad and no coolant in the oil. Have bush hogged. Sicklebar cut some hay, raked it and then baled it. It was a trying experience but was well worth it. Cant upload a current pic for some rteason.
Now thanks a million for the part number info. Needed to help a gentleman out who has a TE20 and all the Bolts on the main gear sheared off and broke the housing where the pinion gear bearing is.
