Burroskinner
New User
Thanks to everyone for their replies on my t30 tractor. Unfortunately it is still doing the same thing. I took the carb. apart and cleaned it along with pulling the fuel bowl and cleaning the filter and blowing out the gas line. I also checked the oil bath air cleaner and replaced the coil. It still starts right up and runs for 5 or so minutes and dies. When it runs under load it has reduced power although the engine seems to be running at normal rpms. After it dies it starts back up and does the same thing all over again. The spark plugs and points look fine. Would a bad condenser cause this? Any more ideas? Thanks
