Can someone tell me the year and model of my tractor
dano3176
New User
I just acquired a Harry Ferguson tractor to restore and I have two serial numbers one is located on the engine which from what I have read makes the engine a 129 engine id is z129a 6005-S 1492. and the serial number up by the steering wheel says TO-99855 so not sure about that one. Thanks for any info in advance Dan
This post was edited by dano3176 on 07/20/2021 at 05:12 pm.
Im using the classic view site and on the left column under research & info check out the Serial numbers page. Use your tractors serial number from
the dash
(quoted from post at 17:20:46 07/21/21) Im using the classic view site and on the left column under research & info check out the Serial numbers page. Use your tractors serial number from
the dash
Thank you so much for your help
(quoted from post at 21:10:11 07/22/21)
the dash
Also, from Modern you can click on the Yesterday's Tractor Co. logo at the top left of the page and it will take you to the home page where the serial number listings and other things are in the index down the left side of the home page.
the dash
Thank you Tom H!
