Set to TDC Mark or 7 mark on flywheel?
xfratboy
I'm still working on getting this TO20 to fire up. No doubt the timing was a mess. When lining up the timing notch on the chassis, do I set it to the DC or 7 Mark? I have it set to DC now but I thought I read it needs to be at seven however I'm a little confused about everything.
Set it at 7 before DC.
Also be sure the engine is on #1 compression stroke.
Have the distributor loose, rotate the housing CCW until the rotor is near the #1 cap tower, then
rotate the CW until the points just break, tighten it down.
That should get you close enough to get it started.
(quoted from post at 16:14:29 07/18/21) Set it at 7 before DC.
Success!! First time she's ran in years!
(quoted from post at 05:53:12 07/19/21) Good job xfratboy. You got him running.
[video play=false:5f60cf07d8]https://forums.yesterdaystractors.com/videos/mvvideo78753.mp4[/video:5f60cf07d8]
Resurrection Sunday!
