Trouble with a hole
Joker917
New User
Hey everybody Ive search the forums and I just cant seem to narrow down what does hall in my T 20 is for. She can run, with some help. But after attempting to start it itll shoes fluid out of this hole am I missing a part or is this normal.
(quoted from post at 15:03:04 06/02/21) Hey everybody Ive search the forums and I just cant seem to narrow down what does hall in my T 20 is for. She can run, with some help. But after attempting to start it itll shoes fluid out of this hole am I missing a part or is this normal.
If you tried to post a picture, it isn't there. Not always, but in most cases new users have to have 5 or more posts on record before the site lets them post pictures, due to site spam filters. Another option is to go down to the Site Comments Forum and ask YT Support for permission to post prior to that. You can try going down to the Test Forum and making several posts there to get your post count up, trying to attach your pictures to each post. That may work after you make several posts. Then make your post here again. It may not work immediately after you get past the 5 posts, if not, you might try logging out and back in at that point. There is a size limit as well, I think it is a total of 7mb per post (be it one picture or the total of several). Some pictures (often taken with phones), are too large and have to be reduced before they will post.
Your description leaves a bit to be desired. To start with were is this hole located? How big is it? What fluid runs out of it?
Youre right I tried to upload photos that were too large and then it said the words violated the terms of service the whole is about 2/3 of the way up on the forward part of the tractor just passed the transmission or transfer case I guess it is Im still kind of learning as I go but yeah its a bout an inch wide Ill work harder on getting the picture posted thank you for your help
Joker is this mysterious hole underneath the bell housing? If so it's a weep hole to let oil that leaks out of the main seal out and is normal , don't plug it .
