12V conversion starter question
thanks, i now know. kind of a stupid question but as i've never had to do it on a positive ground deal, i though i'd better ask before i hosed up a starter drive
If you want the engine to run backwards, rewire the starter to reverse rotation when engaged and change the cam.
Engine will then run backwards.
Good on Marine applications with twin engines.
(quoted from post at 23:38:11 02/20/21) If you want the engine to run backwards, rewire the starter to reverse rotation when engaged and change the cam.
" rewire the starter to reverse rotation when engaged and change the cam.
Engine will then run backwards. "
NO, it won't, starter drive will simply "overrun" and won't engage or crank the engine.
