After removing the spindles and the bushings I was going to reuse the thrust bearings till I found this.
This is the way the bearings were oriented. Notice the two that have turned over and the grooves the rotating bearings have carved into the keeper. Both sides (right & left) were identical to this.
I presume the bearings should all be oriented in this manner, or that is how I am going to put the new ones in when they arrive unless someone says otherwise.
