Company Logo Shop Now
Machine Shop Work
glenmorebuckman
02-06-2021 18:52:34
I am wanting to take the crankshaft for my to30 to machine shop to have it ground and also need to have the rod bushings put in and reamed. I haven't found a shop yet but was wondering, will I need to provide anything other than the crankshaft, rods, bushings and pins. Will they know what specs to grind the shaft to or will I need to provide specs?
Steve@Advance
02-08-2021 19:43:24
 Re: Machine Shop Work in reply to glenmorebuckman, 02-06-2021 18:52:34
They should have the specs if they are interested in grinding it. So many shops now only want to do the new stuff, not interested in having to do research. If you have the specs, wouldn't hurt to give them the numbers just for comparison.
I would take them the new piston pins so they can measure them. The tolerances on wrist pin bushings is really close.
Caseboy1
02-06-2021 19:23:37
They should know the specs on your crank. They'll have info on the journal size and bearings.
Bruce(OR)
02-06-2021 19:00:26
You might want to check this site for parts. I have priced a locally turned crank versus having one shipped in and I have found on occasion that a box one is less money and sometimes faster.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
Latest Ad: Looking for an original IH 730 Plow Operators Manual. Not interested in a CIH reprint. Thank you [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
