Company Logo Shop Now
Fitting hitch to TE20 front
derwen1959
02-06-2021 10:49:55
First I am in uk and I have been welding for a longtime.. has anyone made a hitch for front of TE20 so that a trailer can be attached? As I might be asked to make one and I want to get some ideas Thanks for replies
derwen1959
02-12-2021 02:00:48
 Re: Fitting hitch to TE20 front in reply to derwen1959, 02-06-2021 10:49:55
I have more details.. it looks like I will be doing job. The guy has medical condition,he has difficulty looking behind. Fitting hitch to front axle would be easiest but will not be best . I will make some sort of frame to fit front of tractor , I will not be able to weld frame together on tractor because sparks and gasoline are not a good combination! The trailer is 7'6 x4'6
Charles in Aus.
02-06-2021 18:46:42
An old removable box hitch with a 10 mm flat plate welded to the end works well for light work . Space holes in the plate to suit the front axle holes and bolt straight on . Off set to one side as it will be makes manouvering into tight spaces easier as well .
Rogeriniowa
02-06-2021 12:52:48
Front hitch is used mainly for moving empty trailers and wagons around the yard or paddock. Not for heavy tongue weight or loads at a distance in front of radiator.
Jim L WA
02-06-2021 11:18:03
Take a look at a bumper offered for sale on this site. Go to parts, Ferguson, TE20, sheet metal and body parts. The ones designed for Fords have a tongue welded on to just install a hitch ball.
sunbeam
02-18-2021 15:14:18
 Re: Fitting hitch to TE20 front in reply to Jim L WA, 02-06-2021 11:18:03
Not to heavy duty But guys around here use them to back 4 wheel wagons.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
Latest Ad: Looking for an original IH 730 Plow Operators Manual. Not interested in a CIH reprint. Thank you [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
