Company Logo Shop Now
Busted lift cylinder TO35
Jferguson5959
02-04-2021 12:40:24
My lift cylinder on my TO35 is broken . I'm having a hard time finding one in stock anywhere. Does anybody know if I can use a different 2.5" cylinder on this tractor ? Part # 180967M1 serial number on tractor is 164879.
mooseracing
02-23-2021 11:45:35
 Re: Busted lift cylinder TO35 in reply to Jferguson5959, 02-04-2021 12:40:24
The steiner one is not for a 35, it has different mounts.
I put in a new pump in my '55 last year, kept the old lower pressure relief but went to a 3" piston and cylinder due to the parts issues.
shaeff
02-22-2021 06:15:03
Steiner:
scoobieguy
02-21-2021 16:50:04
There is a 180967M1 on ebay from reliable after market parts, its expensive.
And this one in Texas 180967M1 Massey Ferguson 35 Draft Control Cylinder call New Available
Located at: Broke F Farm Supply in Commerce, TX (903-886-8779) bffstx@gmail.com
Category: Hitch/Drawbar Stock #: 32937
John Deere D
02-10-2021 21:26:05
Call this number..... 1-877-319-0059
Call this number... 1-800-481-1353 or (613) 475-1771 and by fax (613) 475-3748
Tell them who you are, your location, and the part you require..
Bob..
pomester
02-10-2021 15:49:35
They have a pretty good boneyard - did you discuss a used part?
pomester
02-10-2021 07:03:22
I am not allowed to attach a link because it goes to a competitor. Put this number - UM70782 - into google search and check out the first hit.
Jferguson5959
02-10-2021 11:47:54
 Re: Busted lift cylinder TO35 in reply to pomester, 02-10-2021 07:03:22
Called them. They said the photo was just a generic picture and they don't have any in stock and it's not showing until October . This part is very elusive
Jferguson5959
02-10-2021 09:02:10
Thank you. I looked at it and it doesn't have the mounting holes all the way through like mine and I'm not sure if it has the side holes to mount the lever controls too like mine . I called them though and they're gonna calle back. It does say it is a replacement for the part I'm looking for though so hopefully it'll work. I'm a machinist Soni can modify if need be.....I'd just rather not start from scratch.
pomester
02-10-2021 07:01:10
check out this address
http://www.link_disallowed/acatalog/UM70782---Lift-Cylinder--2-1-2---Replaces-180967M1-128318.html
pomester
02-10-2021 06:58:33
Check out this link
Thehickdaddy
02-05-2021 08:26:33
And while we are on the topic, is there such a thing as updated lift pistons that use o rings and backers like modern hydraulics instead of stock original steel split piston rings?
I am sure I was told about them years ago but have not ever found them
John Deere D
02-05-2021 09:53:19
 Re: Busted lift cylinder TO35 in reply to Thehickdaddy, 02-05-2021 08:26:33
See parts as per this forum.. "YT"..
The next 2 1/2 Diam piston cylinder bore I work on shall receive one of these.....
Bob..
Lift Piston - This is a single groove Hydraulic Lift Piston that measures 2-1/2 inches in diameter, groove is centered 1 1/4 inch from bottom of piston. O-Ring available as NAA533A and back up washer as NAA473A. For tractor models 202 Indust/Const, 35, 35X, 50 Loader, TE20, TEA20, TO20, TO30, TO35. Replaces 181983M1. (Part No: NAA530B)
Thehickdaddy
02-07-2021 02:51:14
 Re: Busted lift cylinder TO35 in reply to John Deere D, 02-05-2021 09:53:19
Thankyou kindly
Ark68SS
02-04-2021 21:30:10
That's a 3", he's looking for a 2 1/2". :(
BillL
RM-MN
02-04-2021 16:32:29
In stock, should get it by next Monday if you order now.
graham_in_NJ
02-04-2021 12:52:05
Check fleabay (and other parts dealers). Aftermarket ones listed for TO-35....
Jferguson5959
02-10-2021 06:23:34
 Re: Busted lift cylinder TO35 in reply to graham_in_NJ, 02-04-2021 12:52:05
I have. The only thing I can find is people who have donor tractors that wanna selle a used one and it usually takes them a week and then I find out it's no good anyway. I'm a a machinist, I think I'm just gonna make one.
RM-MN
02-05-2021 03:44:10
2 1/2" lift cylinder.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
Latest Ad: Farmall 350 , 450 and 560 utility fenders. Excellent condition original. Can send pictures if interested [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
