I haven't been using the TO 30 much this summer. It has always smoked since resurrecting it in 2016 from 17 year damp storage. Its valve train was stuck from corrosion, and disallowing engine to be turned over by hand. I dumped several ounces of ATF in each cylinder letting it soak for a month before turning over by hand. Then before trying to turn over engine with starter the oil pan and valve cover were removed cleaned of sludge. Valve train was removed, disassembled, all corrosion & sludge deposits removed, and reassembled with all parts in same location as found. That was about 20 engine hours ago, fast forward to Nov 2020.
Over the 20 hours and four years, many spark plug cleanings were performed. My assumption was the engine probably has stuck rings, surface rust on one or more cylinder walls, and dead valve seals, not to mention the ATF treatment. Engine smoking gradually lessened with use to a few minuet long display after start up (worn valve and or bad valve seals) over the 20 hours. My thought was the engine was slowly self polishing the cylinder walls, perhaps stuck rings were also freeing up.
Number 4 plug consistently would oil foul needing cleaning after every use, the other three also slightly fouled remaining serviceable probably due to a too rich condition. I have leaned up the carburetor, and now no black smoke during rev-up.
Yesterday required a few hours of tractor use, I hadn't checked or cleaned #4 plug for last five hours of operation as the exhaust blue smoke has subsided greatly. That morning on start-up I noticed that oil pressure was just above zero, last time I ran it it was 10 to 15psi at 140* engine temp. To my surprise she was down four quarts of oil, and it hasn't been leaking it.
Once the oil was topped off oil pressure is back around 10 psi at idle, and 15-18psi above idle as shown on a new 60 psi gauge, and still not smoking real bad.
After yesterday's project finished I saw fresh oil puddling below #4 plug along the indented flat of the head, and dry as a bone above the plug up to valve cover gasket. Strange that oil appeared to be leaking from combustion chamber out around the plug's metal gasket ring. Never have seen that before.
So when I removed #4, found it to be solid caked with oily black deposit. Engine had not been misfiring, except for an occasional exhaust pop like a valve was hanging open.
At a minimum I need to replace valve seals. I did scrape clean the sealing surface that the plug's sealing ring seats on in hopes of stopping oil bypassing it.
I guess the best thing is to pull the head, check valve guide's condition, replace seals, and examine cylinder walls, and prepare mentally for a major engine overhaul.
Any tips welcomed.
Before I dig in to engine work that Wagner Loader #WM-4 has to be removed from the tractor. It's a total PIA to engine access.
Any tips welcomed.
