Just picked up a TO20 for a few hundred bucks. Starting to deal with the basics.
-Drained engine oil. The filter that came out was a NAPPA Gold 1107 (metal canister). Found an oil filter on Amazon, Baldwin P40. Is this the right filter? What oil should I use? 4qts came out. What is the capacity?
-No oil was in the hydraulics case. Looks like the seal at the PTO needs to be replaced. Part on order. What oil should be used in the pto hydraulics case? How much? Seems like I read 18qts somewhere.
-What oils and service items need to be done? I already dropped and cleaned the air cleaner.
- What is the screw/filler plug that's under steering wheel?
-Ordered a TO20 alternator conversion kit. Any gotcha's to that process?
