Dirtydog
New User
ok new to ferguson tractor 1949 T030, can't find what oil to use in this tractor
does it need non det oil ? and what weight oil my Oliver uses non det.330 would that be ok for this one to ? 1949 T030
There is no logical reason what so ever to use non-detergent oil in any thing. The oils we have now days are by far better then what there was when these tractor where made. I run 20W-50 oil in almost every thing I own and I have around 30 tractors
Use detergent oil but check the dipstick after a short amount of running. The detergent will clean up the engine and deposit any material it loosened into the oil. If the oil is very dark, change the oil and filter again as you now have a much cleaner engine.
