Paramedicrn
New User
Hey all!
My wife and I have acquired a true barn find. 1955 TO-35 Serial # 140868. Four gauges. Been parked so long that the tires are flat and the bottoms have rotted. Engine rolls over. Grabbed a 625 CCA 6V battery from Rural King and it will spin with the plugs out, but has to work hard with them back in. I need to pull of the gas tank to clean it. I can't get the sediment bowl to unscrew from the bottom of the tank at this point or the bowl to come off of the assembly either. Tank seems to be solid, just some crude in that I want to clean out. I'll move some pics over from my phone and post up in a bit if I can get logged in with tapatalk. Otherwise I'll email them to myself and post them up tomorrow.
I will bug you guys with questions as I get moving on this thing. I hope to pull it out on the flats under it's own power and then load it on a trailer to bring home. She'll get an oil change and fresh coolant prior to starting and moving. I just want to get her home where I have some air tools to be able to pull off the wheels and get new tires mounted. I am going to have to replace the rim on the back left due to the lugs rusting off of the current one.
Pics soon!
B
Pics soon!
B
