demongo1129
New User
so i need some help here, been fighting with this tractor for a few months now. been through complete carb rebuild, intake/exhaust manifold cleaning and resurfacing, new spark plugs, re timed entire engine, tested compression, and went through resetting governor and throttle linkage. no matter what i get the same result, tractor is hard to start, runs ruff and the throttle lever does nothing to the engine rmp and then it dies out. it is easier to start when cold, harder when hot.
compression when cold was 100psi on cylinder 1 and 4, 90psi on 2 and 3. could use any advise on what could be wrong
