Sherman live power for TO-30 -parts.
sam c
My mechanic ha a TO-30 with shermanlive power clutch (I had never seen one till this one)
it does not work.
Does anyone know if parts are available. I have found a manual
Those items went out of production long ago. You might have better luck finding Howard transmission parts. You have the third one I have heard about in some 20 years. Live power can now be done with the addition of an external pump from the front pulley. A cheap way out is a transport lock which holds the implement off the ground.
I guess I must be the luckiest Fergie owner ever.....I've got two of them, both with Sherman combos, and factory tachs.
The sad part is that they are both still in their work clothes. That last one has 1562 hours one it, if I remember right.
Irv
(quoted from post at 06:12:11 08/15/20) I have one. There is a adjustment on right side. Adjust screw in or out. This may be all it needs. I'll take a picture today.
have been looking at derelict tractors for forgotten options. I would be interested in seeing the adjustment screw and lever.
Thank's
